complex numbers/constants in parametric sweeps
While trying to set up a parametric sweep, I need to use complex numbers as the constant values. I get the following error "A complex constant was encountered during expression evaluation".
Does anyone know how to enter complex numbers for parametric sweeps?
I can successfully enter the complex valued expression in the Global Definitions-> Parameters. But i need to use it in the parametric sweep.
1 Reply Last Post 2011/12/03 6:11 JST
Posted: 1 decade ago 2011/12/03 6:11 JST
I would try with two real parameters (a pair per sweep) and then combine them in the equation
Hi I would try with two real parameters (a pair per sweep) and then combine them in the equation -- Good luck Ivar
