Contracting vessel
I’m interested in performing a model of a contracting heart (or at least one ventricle). Is COMSOL capable of performing such a model where the vessel walls contract?
Thanks allot
Hemi
3 Replies Last Post 2011/12/20 22:58 JST
Posted: 1 decade ago 2011/12/07 0:01 JST
Yes. You need to setup it up as a Fluid-Structure interaction model. You can model the contraction using initial strains.
Nagi Elabbasi
Veryst Engineering
Yes. You need to setup it up as a Fluid-Structure interaction model. You can model the contraction using initial strains. Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 2011/12/19 19:23 JST
Thanks Nagi
If I'm correct, your intension was to perform a model for the contracting heart (using strains on elastic body which I will set it's parameters) and to couple the model to a flow model. In fact my case is allot more simple, I'm not interested in a two way coupling. The way the heart contracts is well established I'm more interested in the flow derived from the contraction. Is there a simple way to preset the deformation of my vessel (as a boundary condition) and to perform a model on the derived flow?
Thanks allot
Hemi
Thanks Nagi If I'm correct, your intension was to perform a model for the contracting heart (using strains on elastic body which I will set it's parameters) and to couple the model to a flow model. In fact my case is allot more simple, I'm not interested in a two way coupling. The way the heart contracts is well established I'm more interested in the flow derived from the contraction. Is there a simple way to preset the deformation of my vessel (as a boundary condition) and to perform a model on the derived flow? Thanks allot Hemi
Posted: 1 decade ago 2011/12/20 22:58 JST
Yes you can couple the fluid flow with moving mesh only (no structure) and use that to displace the fluid boundary.
