Need help in writing a function.
Hi, i am very new to comsol and i need help in writing a funtion
I have a phase change model and i need variable dynamic viscosity.
The variable dynamic viscosity is input as a piecewise, continuous, second derivative function as follows:
V=10^8 for T<303K
V=0.008 for t > 306K
How do i input as a function?
I would be glad if there is other place where i can learn how to write a function.
Tim
3 Replies Last Post 2015/11/06 11:58 JST
Posted: 1 decade ago 2011/12/15 0:21 JST
I would propose to use an analytical function with a step function and use the "transition zone to go from one level to the next.
But another issue I see is the step size 10^8 to 10-2 which is 10 orders of magnitude change over 3 K temperature difference, I'm afraid you are demanding too much for the binary representation of numbers there, a regular slope of 3E9 : 1 is very tough.
Nevertheless try it, but I suspect some solver issues in view
Hi I would propose to use an analytical function with a step function and use the "transition zone to go from one level to the next. But another issue I see is the step size 10^8 to 10-2 which is 10 orders of magnitude change over 3 K temperature difference, I'm afraid you are demanding too much for the binary representation of numbers there, a regular slope of 3E9 : 1 is very tough. Nevertheless try it, but I suspect some solver issues in view -- Good luck Ivar
Lechoslaw Krolikowski
Posted: 1 decade ago 2011/12/15 0:24 JST
You can use step function. See documentation, for instance, Introduction to Comsol Multiphysics v.4.1, pp. 30-32.
BR
Andrzej
Hi, You can use step function. See documentation, for instance, Introduction to Comsol Multiphysics v.4.1, pp. 30-32. BR Andrzej
Posted: 10 years ago 2015/11/06 11:58 JST
Hi, Tim
Have you solved the problem? I come with the same problem with you.
I am a newer in comsol, I don't know how to deal with it.
Could you give me some help?
Howie,
Thanks!
Hi, Tim Have you solved the problem? I come with the same problem with you. I am a newer in comsol, I don't know how to deal with it. Could you give me some help? Howie, Thanks!
