error:singular matrix
When i try to compute a stationary problem of a 3d model,singular matrix occurs,like: - Feature: Stationary Solver 1 (sol2/s1) Failed to find a solution. Singular matrix.
For mesh-case 0 there are 29578 void equations (empty rows in matrix) for the variable comp1.V. at coordinates: (-0.04,-0.04,-0.04), (-0.04,-0.032,-0.04), (-0.04,-0.036,-0.04), (-0.036,-0.04,-0.04), (-0.032,-0.04,-0.04), ... and similarly for the degrees of freedom (empty columns in matrix). Returned solution is not converged. Not all parameter steps returned. i find one of my material,air,has a 0 conductivity(default).then i change it to a tiny value,like 1,the singular matrix problem disappears.
1 Reply Last Post 2020/04/01 8:00 GMT-4
Lars Dammann COMSOL Employee
Posted: 6 years ago 2020/04/01 8:00 GMT-4
Hi, changing the conductivity to a small, finite value is indeed a very common fix for this problem. This is usually not a big problem for most models as the error by the tiny conductivity should be negligible. You can make some models work with exactly 0 conductivity by adding/removing gauge-fixing or by using a different interface. This depends on your model, though. I could give more specific advice if you could post your model here. Best regards, Lars
