how to simulate the breakdown voltage in COMSOL?
hi, how could I use COMSOL to calculate the breakdown voltage in the dielectric?
6 Replies Last Post 2013/08/07 11:30 GMT-4
Posted: 1 decade ago 2012/02/13 19:18 GMT-5
I don't think you can do that, at least not directly. Comsol computes the solutions of partial differential equations subject to various constraints, boundary conditions, and initial conditions. Thus, you would need to express your breakdown physics in terms of those kinds of equations.
That said, you can certainly model the electric fields in and on your dielectric, and then, given a breakdown condition (e.g., such that if E > some user-entered threshold value, you would call it a breakdown condition), you could predict whether or not breakdown would be likely in any particular geometry. But that would not be modeling the actual physics of breakdown itself, which is a very complicated phenomenon. In fact, there is no shortage of literature, and ongoing research, in this subject.
I don't think you can do that, at least not directly. Comsol computes the solutions of partial differential equations subject to various constraints, boundary conditions, and initial conditions. Thus, you would need to express your breakdown physics in terms of those kinds of equations. That said, you can certainly model the electric fields in and on your dielectric, and then, given a breakdown condition (e.g., such that if E > some user-entered threshold value, you would call it a breakdown condition), you could predict whether or not breakdown would be likely in any particular geometry. But that would not be modeling the actual physics of breakdown itself, which is a very complicated phenomenon. In fact, there is no shortage of literature, and ongoing research, in this subject.
Posted: 1 decade ago 2012/09/26 19:17 GMT-4
I have been thinking about a shortcut by creating a non-linear material with conductivity depending on the magnitude of the E field. The simplest way to do it would be to have a type of step function that raises the conductivity once Enorm goes over a certain value.
To create a material I tried following the example of the "Soft Iron (with losses)" from the Materials Library (within the AC/DC materials. The soft iron with losses calculates the norm of the B and H, based on the three values for Bx, By, and Bz (called B1, B2, and B3 within the Model inputs).
In the material properties I went to the Quantities>Model Inputs, right clicked "Electric Field" and added it. This allows you access to Ex,Ey, and Ez (called E1,E2,and E3). You then calculate normE by sqrt(E1^2+E2^2+E3^2). Then, you can make the Electrical conductivity (sigma) dependent of this normE. However, when I try running a test, I get a buch of errors. Of course it must be some kind of chicken and egg problem. There must however be a way to run this as a parametric or time dependent model in which you start with normE=0 and allow it to increase as the potential is raised.
Any ideas on doing this?
I have been thinking about a shortcut by creating a non-linear material with conductivity depending on the magnitude of the E field. The simplest way to do it would be to have a type of step function that raises the conductivity once Enorm goes over a certain value. To create a material I tried following the example of the "Soft Iron (with losses)" from the Materials Library (within the AC/DC materials. The soft iron with losses calculates the norm of the B and H, based on the three values for Bx, By, and Bz (called B1, B2, and B3 within the Model inputs). In the material properties I went to the Quantities>Model Inputs, right clicked "Electric Field" and added it. This allows you access to Ex,Ey, and Ez (called E1,E2,and E3). You then calculate normE by sqrt(E1^2+E2^2+E3^2). Then, you can make the Electrical conductivity (sigma) dependent of this normE. However, when I try running a test, I get a buch of errors. Of course it must be some kind of chicken and egg problem. There must however be a way to run this as a parametric or time dependent model in which you start with normE=0 and allow it to increase as the potential is raised. Any ideas on doing this?
Posted: 1 decade ago 2013/07/29 10:40 GMT-4
I am also interested in this. Any ideas anyone?
John
I am also interested in this. Any ideas anyone? Thanks, John
Posted: 1 decade ago 2013/07/29 11:08 GMT-4
with a field dependent material as indicated by Jose you may be able to see where a breakdown starts if you already know the breakdown fieldstrength in the material of interest.
But as Robert already pointed out this is far from simulating the breakdown process itself.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
Hi, with a field dependent material as indicated by Jose you may be able to see where a breakdown starts if you already know the breakdown fieldstrength in the material of interest. But as Robert already pointed out this is far from simulating the breakdown process itself. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology
Posted: 1 decade ago 2013/07/29 14:23 GMT-4
I would also add that in order to simulate the details of breakdown, this is getting into plasma type physics. This is quite involved as its own thing.
There are several books available for high voltage design work. You could seek those out. There are some books over at:
archive.org/details/texts
that may help. Search for Dielectric Phenomena by FW Peek. It is an older book and its free. It will help with some of the math behind the scenes with simpler structures. It is also a theory book.
I agree that the best you can do in comsol for something like this is to determine the E field strength. It would be up to you to determine if that strength is too much.
I would also add that in order to simulate the details of breakdown, this is getting into plasma type physics. This is quite involved as its own thing. There are several books available for high voltage design work. You could seek those out. There are some books over at: http://archive.org/details/texts that may help. Search for Dielectric Phenomena by FW Peek. It is an older book and its free. It will help with some of the math behind the scenes with simpler structures. It is also a theory book. I agree that the best you can do in comsol for something like this is to determine the E field strength. It would be up to you to determine if that strength is too much.
Posted: 1 decade ago 2013/08/07 11:30 GMT-4
OK. This is what I was thinking too. I understand that electric breakdown is an extremely complicated process.
John
OK. This is what I was thinking too. I understand that electric breakdown is an extremely complicated process. Thanks, John
