Trajectories outside the physical domain in the particle tracing module
Posted 2012/02/20 15:38 GMT-5 Charged Particle Tracing, Particle Tracing for Fluid Flow Version 4.2a 2 Replies
Hey,
I ran a simulation of the behavior of a polymer inside an extrusion tube die by using laminar flow module and the No-Newtonian Carreau Module. Afterwards I added the particle tracing module using the drag force formulation. However, the particle trajectories are located outside the phyical domain. Attached are three pictures with the geometry, the particle trajectories and the poincaire map in order to clarify the problem.
Any ideas why this is happening? Should I used the massless formulation instead?
2 Replies Last Post 2012/02/24 0:46 GMT-5
