                                2012/03/06 14:07 GMT-5
                                                    Does negative concentration in your case means that you have more charges of the opposite sign? Then it wouldn't be very physical to limit it to only positive values.
In general, if you are sure that you are getting some unphysical values, then you equations are probably wrong somewhere.
                                2012/03/06 16:36 GMT-5
                                                    Thanks for your answer.
I agree that I might come up with some physical meaning of the negative concentration during solution. However, since I use two chds module for both electrons and holes, at least I didn't expect the negative concentration in the final result.
I just curious that is there way to put constraints on variables?
                                2012/03/06 21:06 GMT-5
                                                    to constrain a variable to positive-only, just use abs() operator. But if the negative number comes out of the solution of your equations, then it's negative because your equations say so. You can't change the result until you change equations.
                                2012/03/07 4:47 GMT-5
For complex problems, the uniqueness of solution is difficult to guarantee. In my opinion, the solution from COMSOL is partially determined by how the discrete equation system is assembled. Thus it's also reasonable to have non-physical solution from CMOSOL. When you impose some additional constraint, it starts to give some different solution.
