Geometry Addition With Time-Dependent Solving
Is it possible to vary one dimension of the geometry in a Time-Dependent problem
The process i'm modeling involves injection of material with time and moving heat flux on one its surface along which material is getting deposited with time.
www.comsol.se/community/forums/general/thread/17099/
I tried the methods mentioned in that thread
>Parametric Sweep - Doesn't takes the final solution, starts over from 0 time
>Initialise t=0[s] in the parameters( under Global Definitions node) - doesn't updates the geometry
>Deformed Geometry(dg) - streches the geometry in spatial frame with solutions from previous time frame
>Moving Mesh(ale)- moves the geometry in spatial frame.
Am i missing anything.
Many thanks for any clarification/suggestions.
2 Replies Last Post 2014/12/14 2:13 JST
Hello Mohit Janoiya
Posted: 1 decade ago 2014/03/04 11:38 JST
hi Mohit,
I am experiencing a similar problem and I am so puzzled, have you solved the problem? I really want to know how to deal with it. thank you
I'll keep you in touch with this.
hi Mohit, I am experiencing a similar problem and I am so puzzled, have you solved the problem? I really want to know how to deal with it. thank you I'll keep you in touch with this.
Posted: 1 decade ago 2014/12/14 2:13 JST
Hi Guangxi,
Havent solved that problem, in comsol atleast. New version might have found a way of doing that.
If by any chance you are in Mumbai, Dec 18-19, 2014; you can attend the conference.
www.comsol.co.in/c/1cxx
www.comsol.co.in/c/1cxz
080-4092-3858
ajay@comsol.com
Hi Guangxi, Havent solved that problem, in comsol atleast. New version might have found a way of doing that. If by any chance you are in Mumbai, Dec 18-19, 2014; you can attend the conference. www.comsol.co.in/c/1cxx www.comsol.co.in/c/1cxz 080-4092-3858 ajay@comsol.com
