Couple level-set multiphase flow with heat transfer in fluids
Posted 2020/11/24 9:09 GMT-5 Version 5.1 1 Reply
Dear
I would like to simulate two-phase flow (Oxylene-Nitrogen ) through a channel of 3.4 mm in diameter with heat transfer from the channel wall to the fluid. It is quite simple to simulate this case for one-phase flow, but there is no built-in multiphysics coupling of heat transfer and multiphase flow available in COMSOL. I am using the level set approach with version 5.1 of COMSOL. Is it possible to couple these physics to obtain temperature profiles in the fluid? If so, what is the most convenient way to do this?
Thank you.
