Make material parameter change based on Frequency of solver
How can I make a material, such as permittivity, pull from a function or list based on the freqency the solver is using?
For example, if a material as a permittivity at 100MHz and another at 10GHz, how can I have that handled without manually editing the material, then recalulating the mesh, then recomputing? I'd much rather just run a compute once with both parameters.
(Note I am using Comsol 5.5, and cannot upgrade to 5.6 at this time)
3 Replies Last Post 2020/12/20 2:39 JST
Posted: 5 years ago 2020/12/19 1:31 JST
Permittivity (and a lot of other things) can be an explicit function of frequency.
Posted: 5 years ago 2020/12/19 4:30 JST
Is there a tutorial on explicit function linking like this that you could please point to?
>Permittivity (and a lot of other things) can be an explicit function of frequency. Is there a tutorial on explicit function linking like this that you could please point to?
Posted: 5 years ago 2020/12/20 2:39 JST
You don't need a tutorial. An example
replace 4 for permittivity by 4 -2*(freq>1[GHz])
You don't need a tutorial. An example replace 4 for permittivity by 4 -2*(freq>1[GHz])
