Post-processing query
Hi all,
I am looking for some help in the post-processing regarding the following points:
1. Plotting the two variable results (say stress and strain) on the X-Y graph in the transient run. How to do it?
2. Consider a 2d cantilever beam, constrained on one end and force applied on the other end. I need to take a average stress on the center of beam. How to take an average?
Please share your expertise.
Thanks in advance,
Rakesh
3 Replies Last Post 2010/01/28 15:18 JST
Posted: 2 decades ago 2010/01/27 15:52 JST
There are a few tricks with the plotting, but at least in V3.5a you have very many options, I suppose you want to do somthing like what can be found in the Cross-Section Plot parameter GUI, by playig with the "keep plot" to overlay several variables, possibly to change the default X-axis data to an expression. You cannot get absolutely everything imaginable, but most required plot are possible, with a little imagination. This does not mean that it is easy when you do 10 runs and have to reapeat the numerous mouse clicks to get out a complex plot. But this will be greatly facilitated in V4 (hey COMSL developpers get it out, even if it is not "perfect" yet ;) as you can record full sequences for later replay them without clicking as hell.
For your average, it rather easy I believe: use the "Options Integration Coupling Variable" with these integrate your desired expresson over an edge/boundary respectively sub-domain. To get out a mean value you must "just" divide the result by the length/area respectively Volume that you get by integrating "1" over the same edge/boundary respectively sub-domain.
Note that this is rather easy if you have "cut-out" your edge, boundary respectively sub-domain so you can select it as a separate item, but you can also restrict to a limited domain by multiplying your expression by a bolean expression depending on the gemetrical variables to limit the region <>0. Again do not forget to use the same bolean expresson for the length/area/volume calulation you use for normalisation.
Hi There are a few tricks with the plotting, but at least in V3.5a you have very many options, I suppose you want to do somthing like what can be found in the Cross-Section Plot parameter GUI, by playig with the "keep plot" to overlay several variables, possibly to change the default X-axis data to an expression. You cannot get absolutely everything imaginable, but most required plot are possible, with a little imagination. This does not mean that it is easy when you do 10 runs and have to reapeat the numerous mouse clicks to get out a complex plot. But this will be greatly facilitated in V4 (hey COMSL developpers get it out, even if it is not "perfect" yet ;) as you can record full sequences for later replay them without clicking as hell. For your average, it rather easy I believe: use the "Options Integration Coupling Variable" with these integrate your desired expresson over an edge/boundary respectively sub-domain. To get out a mean value you must "just" divide the result by the length/area respectively Volume that you get by integrating "1" over the same edge/boundary respectively sub-domain. Note that this is rather easy if you have "cut-out" your edge, boundary respectively sub-domain so you can select it as a separate item, but you can also restrict to a limited domain by multiplying your expression by a bolean expression depending on the gemetrical variables to limit the region 0. Again do not forget to use the same bolean expresson for the length/area/volume calulation you use for normalisation. Good luck Ivar
Posted: 2 decades ago 2010/01/28 12:07 JST
Thanks for the explanation Ivar.
I am learning Matlab commands for Comsol. I want to access the dependent variables (say u, v and w) in the Matlab. But the matlab command - fem.sol.u displays the values of all variables u,v and w at all the time in the transient simulation.
How to access and store the each variable u, v and w separately at the particular node for the whole transient run and then plot it in Matlab ?
Also I have defined some global expression in the Comsol. Will it be expressed in the same way as that of dependent variables?
Thanks in advance,
Rakesh
Thanks for the explanation Ivar. I am learning Matlab commands for Comsol. I want to access the dependent variables (say u, v and w) in the Matlab. But the matlab command - fem.sol.u displays the values of all variables u,v and w at all the time in the transient simulation. How to access and store the each variable u, v and w separately at the particular node for the whole transient run and then plot it in Matlab ? Also I have defined some global expression in the Comsol. Will it be expressed in the same way as that of dependent variables? Please share your expertise. Thanks in advance, Rakesh
Posted: 2 decades ago 2010/01/28 15:18 JST
take a look at the discussion about effective modal mass, search for :
Matlab script for effective modal mass extraction
the colums are the different dependent variables for all nodes per row, s usual with FEM to get your way in the geometry you must handle the indexes and the indexes of indexes ...
Hi take a look at the discussion about effective modal mass, search for : Matlab script for effective modal mass extraction the colums are the different dependent variables for all nodes per row, s usual with FEM to get your way in the geometry you must handle the indexes and the indexes of indexes ... Good luck Ivar
