2012/06/22 7:23 GMT-4
Hi!
I use for field lines the isolines with magnetic vector potential Az; this will give a better image.
Since you use infinite elements for large ring, the outer border is the "end of the universe".
So the loop is correct: field lines will close in infinity.
Ralf
Hi!
Ralf
2012/06/22 7:46 GMT-4
a few comments on your model:
- Your infinite area should have a radius of 1/5 to 1/10 of the total air radius, yours is much bigger.
- its better to use the "circle advance tab layer to generate this INF element region, and have the mesher use a mapped mesh with at least 5 elements radially across
- use rather a cylindrical INF element type AND set the centre such that your model is in the middle and that the centre coordinates of your circle are those of the INF element circle
- Parameter and variable names, try avoid single letter names as these are mostly already used by COMSOL, and will not necessarily flagged as an error, as COMSOL allows us to change the internal variables values, but COMSOL cannot tell if it is on purpose or by "error" (I'm thinking particularly about r, w, H)
Why mix a frequency domain AND a stationary like that without any intermediate STORE solution nor any links between them, both overwriting the same Data Set on output ? You cannot tell where the results come from (probably the stationary, as its the last one.
make either separate studies, and one solver per study, or add a "store solution" in between both (if COMSOL hasn't done it for you) and start with a stationary to use that as initial conditions for the frequency domain perhaps ?)
2012/06/25 4:35 GMT-4
Thank you very much for ypur reply and for your Useful comments
it was some additional option as a frequency domain and stationary and a big infinte Area for test
for every thing thank you very much
With my Regard
Maher
With my Regard
Maher
