Inverse heat transfer problem
Posted 2012/06/25 16:13 GMT-4 Heat Transfer & Phase Change, Heat Transfer Version 4.2a 5 Replies
I need to determine the surface temperature by doing an inverse heat transfer problem method.
Experiments are done with impingement of a hot steel plate(900°C) with 3 thermocouples located at 1mm below the surface. The data is measured at a rate of 150Hz. This gives a nice temperature/time dependence at these locations.
Is is possible in COMSOL4.2a to load these data sets from the thermocouples into COMSOL to perform a inverse heat transfer problem to calculate surface temperatures/heat fluxes?
Regards
Regards
5 Replies Last Post 2015/02/03 1:13 GMT-5
