At higher temperature.. cant solve the equaitons
Posted 2012/07/03 22:59 JST Heat Transfer & Phase Change Version 4.2a 2 Replies
I am applying Joule heating in a time-dependent model, I input a constant current to a terminal and grounded the other. I set the initial value of temperature of 1673K for the whole body. When I am running the simulation, it is showing no progress.
But if I take the initial temperature to be aroung 1273K, , its giving me result.
Why is it showing problem at higher temperatures???
(PS: i set the time of 100sec with a jump of 0.1 second
and input all the properties of the material as a function of temperature---> so is it because at the high temperature some properties showing negative values, which were not supposed to be negative??????????)
Thanks in advance :) :)
2 Replies Last Post 2012/07/04 21:56 JST
