Robert Koslover
Certified Consultant
3 years ago
2021/12/12 9:02 JST
Updated:
3 years ago
2021/12/12 10:03 JST
You probably either did your arithmetic incorrectly or used the wrong equation. (After all, 10^46 W is greater than the power output of a supernova.) Regardless, you'll be happy to learn that your simulation gave the correct result to within 1%. Among others, you could take a look at page 16, equation 1-74, in Antenna Theory and Design by W.L. Stutzman and G.A. Thiele, published by John Wiley & Sons, 1981. The equation there will yield P = 10^15 W if using your numbers.
p.s. A static electric dipole moment, p, has units of charge x distance. The dipole moment that you refer to is in terms of current x distance. This is not the same thing, of course. Confusing the two leads to the error you reported.
You probably either did your arithmetic incorrectly or used the wrong equation. (After all, 10^46 W is greater than the power output of a supernova.) Regardless, you'll be happy to learn that your simulation gave the correct result to within 1%. Among others, you could take a look at page 16, equation 1-74, in *Antenna Theory and Design* by W.L. Stutzman and G.A. Thiele, published by John Wiley & Sons, 1981. The equation there will yield P = 10^15 W if using your numbers.
p.s. A static electric dipole moment, *p*, has units of *charge* x distance. The dipole moment that you refer to is in terms of *current* x distance. This is not the same thing, of course. Confusing the two leads to the error you reported.
3 years ago
2021/12/13 22:33 JST
Thanks a lot for your help!
