Temperature Dependent Electrical Potential
I have tried to make a temperature dependent electrical potential. The electric potential will have an initial voltage of 37V which will heat up the biological tissue. As the temperature of the biological tissue increases, I would like to sample the current temperature within the tissue, and use it to control the voltage level (i.e. temperature acts as a negative feedback to voltage, or V = 37 - 0.01T ). I have tried a few different things but none seemed to work so far.
Does anyone know how to implement this? Thanks.
1 Reply Last Post 2022/03/08 3:04 JST
Posted: 3 years ago 2022/03/08 3:04 JST
Updated: 3 years ago 2022/03/08 5:06 JST
Hi Zexi,
I assume you have a potential boundary condition somewhere in the model. Now you need to decide which way you want to sample the temperature. You can define a point probe or an average operator on some domain of interest. Now you can use the point probe value or the average to define an expression like 37 - 0.01*pointprobevalue in the potential BC.
Hope that helps. Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Zexi, I assume you have a potential boundary condition somewhere in the model. Now you need to decide which way you want to sample the temperature. You can define a point probe or an average operator on some domain of interest. Now you can use the point probe value or the average to define an expression like 37 - 0.01*pointprobevalue in the potential BC. Hope that helps. Cheers Edgar
