LI ion battery charge/discharge: initial voltage
Posted 2022/03/21 2:04 GMT-4 Battery Design Version 5.6 1 Reply
hello, I am using 1d electrochemical couple with 3D thermal model to simulate charge/discharge of LI-ION battery. sometimes it's difficult to converge when change air's velocity [error: Failed to find consistent initial values. Singular matrix. Last time step is not converged.],so I delete the fluid domain and use heat transfer coefficient to simplify. then something strange occurr,I get different voltage(t=0s) at the time dependent step. since the li-ion battery part is the same, i dont think different thermal model (initial temperature is 293K) can lead to different t0 voltage. but the result is different,what problem can cause this, initial vuale issue lead to wrong result? looking forward for your help, thank you.
