Value of the force density for a element and not for the nodes of a mesh
Posted 2012/08/06 4:06 GMT-4 Low-Frequency Electromagnetics, Interfacing, Geometry, Mesh, Structural Mechanics Version 4.2, Version 4.2a, Version 4.3 2 Replies
maybe I was not clear, I try to explain more the problem:
The element : the nodes composed a element, for exemple 8 nodes composed a simple linear element (a little cubic).
The object : is the geometry, is composed by elements.
When Comsol transfers the Lorent's force from EM analysis to a structural analysis, it transfer the value corresponding of the first mesh(EM) to another mesh (Structural), but it should to adapt the values of the nodes(Nodes are usually placed at the element corners) between the two mesh,right?. The transfered value (ex.force density) is transfered to the nodes of the second mesh(Structural) with the help of the shapes fonctions of the second mesh, because the elements was differents. The nodes beetwen the two mesh (EM and Structural) have differents coordinates and form. In others words I should to export mf.FLtrz (I think is a distrubution on the object, right?) for the area (or volume) of a single element of the mesh (Em or Structural,type of element: cubic,thetraedral,..),it is possible?
For exemple in Ansys(another FEM program) we could apply a force on a single element(for exemple a little cubic,thetraedral,... the same of the mesh) and than ansys compute the distrubution of this force on the corresponding element with tha shape fonctions. It is possible in Comsol? If it is possible is valid the reverse -> read a force density (Surface or volumetric) of a element?
thank s
thank s
2 Replies Last Post 2012/08/09 9:03 GMT-4
