Is there a way to extend the simulation time and continue after a calculation is finished?
I'm running some jobs with COMSOL 5.6 and after the calculation finished, I found that the results are not enough for me to draw useful conclusions. I need the model to run a longer time. So I'm wondering is there a way that could allow me to extend the total simulation time and continue the job where it finished?
Best wishes
2 Replies Last Post 2022/05/11 8:40 GMT-4
Posted: 3 years ago 2022/05/10 13:54 GMT-4
unfortunately you cannot continue a finished time dependent study. It can be continued if it is stopped before it finishes and you can change the final time in this case. It would be very useful to have the option for a finished study as well, but for some unknown reason this hasn't been made available so far. However, you can set up a second study and use the result of the first study to start with. The second study starts at the final time of the first study. You can join the two datasets later. I used this workaround a few times. You may note some discontinuity at the time interface. Maybe it works with another study step as well but I haven't tried that.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi, unfortunately you cannot continue a finished time dependent study. It can be continued if it is stopped before it finishes and you can change the final time in this case. It would be very useful to have the option for a finished study as well, but for some unknown reason this hasn't been made available so far. However, you can set up a second study and use the result of the first study to start with. The second study starts at the final time of the first study. You can join the two datasets later. I used this workaround a few times. You may note some discontinuity at the time interface. Maybe it works with another study step as well but I haven't tried that. Cheers Edgar
Posted: 3 years ago 2022/05/11 8:40 GMT-4
okay, I see. Thank you for your reply!
