How to visualize the ratio of two result variables in a surface plot?
Hello.
I have a 2-D model. In post-processing, I am able to visualize the surface plot of a variable A. I can also see the surface plot of another variable B in the same model. How can I visualize the surface plot of A/B ? Tried different basic attempts. Non of them is working.
4 Replies Last Post 2022/06/22 12:33 JST
Posted: 3 years ago 2022/06/21 12:53 JST
Updated: 3 years ago 2022/06/21 12:53 JST
What happens if you create a Surface plot, enter A/B as Expression, and click on Plot?
Posted: 3 years ago 2022/06/21 23:58 JST
It shows zero amplitude all over the surface, which can't be true.
>What happens if you create a Surface plot, enter A/B as Expression, and click on Plot? It shows zero amplitude all over the surface, which can't be true.
Posted: 3 years ago 2022/06/22 0:02 JST
And non-of the B values are zero.
>>What happens if you create a Surface plot, enter A/B as Expression, and click on Plot? > >It shows zero amplitude all over the surface, which can't be true. And non-of the B values are zero.
Posted: 3 years ago 2022/06/22 12:33 JST
If you post the model here, or send it to COMSOL Support, then I think that it will be possible to explain the behavior that you observe.
