Thin layers in large volume for magnetic field problem in frequency domain
Posted 2022/11/04 4:27 GMT-4 Low-Frequency Electromagnetics, Mesh, Modeling Tools & Definitions 2 Replies
Currently I am trying to simulate an experimental hall (~25 m x 25 m x 20 m) with walls made of 1 mm thick steel sheets (permeability and conductivity to be taken into account). In this hall there is a rectangular coil (~3 m x 3 m and ~100 turns assembled in a 5 cm x 5 cm square bundle) located close to the metallic wall and driven by oscillating currents at different frequencies up to 2 kHz (low frequency domain). At different locations within this hall, there are also other large stainless steel chambers with small thickness (~1 cm) compare to their other dimensions (~10 m x 2 m x 2 m). Meshing such a system seems quite challenging ! Therefore, in order to be able to simulate such a problem, I am looking for Comsol models or examples showing how to handle large volume with thin metallic layers under the influence of magnetic field in the low frequency regime. More specifically, I would like to understand which boundary conditions could be applied to the thin layers in order to avoid meshing them.
Many thanks for any help.
Gilles
