MEMS
Sudhaman Parthasarathi
How can i compute the displacement due to gravity in a silicon proof mass in accelerometer and therefore i need to compute the change in capacitance in the accelerometer. My basic question is how do i apply force on a silicon block and compute the displacement.
2 Replies Last Post 2013/08/17 2:14 JST
Posted: 1 decade ago 2012/09/15 18:37 JST
if you run a "solid" physics of a geoemtrical system, that is attached by some means to block all free DoFs 3 in 2D, 6 in 3D and then apply a body load (rho*g_const) [N/m^3] or a boundary load [N/m^2] then you should see the deflection.
To get a capacitive change you need one of the ACDC modules and couple the deformation to a squeezing of the air/vacuum region between your electrodes, thiswill give you a change in geometry hence a change in capacitance.
There are several models in the model lbrary and on the Forum
Hi if you run a "solid" physics of a geoemtrical system, that is attached by some means to block all free DoFs 3 in 2D, 6 in 3D and then apply a body load (rho*g_const) [N/m^3] or a boundary load [N/m^2] then you should see the deflection. To get a capacitive change you need one of the ACDC modules and couple the deformation to a squeezing of the air/vacuum region between your electrodes, thiswill give you a change in geometry hence a change in capacitance. There are several models in the model lbrary and on the Forum -- Good luck Ivar
Posted: 1 decade ago 2013/08/17 2:14 JST
what if there're several kind of materials in the model ? How can I apply acceleration on the whole model ?
