One boundary with two boundary conditions (Neumann and Dirichlet)
Please help me to understand about this issue.
I have a system of two PDE equations with two variables (u1, u2) need to be solved in General Form.
On a boundary 1, for example, I set up a Neumann boundary condition:
-n.Γ1 = f1
-n.Γ2 = f2
And then, still on the boundary 1, I set up one more Dirichlet boundary condition:
u1=f3 (Prescribed value of u1)
u2=f4 (Prescribed value of u2)
And I saw Comsol let me know that, the two conditions contribute together. So, which condition in two condition above will perform (affect to u2 on the boundary 1) in my model? (Both of them?)
Thank you so much for your help.
3 Replies Last Post 2015/04/16 9:44 GMT-4
Hello Thanh Lem
Posted: 1 decade ago 2013/02/28 5:17 GMT-5
Hi!
I guess the boundary condition you implement depends on that that you are trying to model, right?
Hi! I guess the boundary condition you implement depends on that that you are trying to model, right?
Posted: 1 decade ago 2013/10/23 12:20 GMT-4
I'm trying to apply a constant heat flux in the energy equation,
for example,
-n(Gamma)=g where g=41000[W/m^2],
but I'm not getting good results. Do you know if I just put g=41000[W/m^2] is correct?
Thanks.
Marco
Hi, I'm trying to apply a constant heat flux in the energy equation, for example, -n(Gamma)=g where g=41000[W/m^2], but I'm not getting good results. Do you know if I just put g=41000[W/m^2] is correct? Thanks. Marco
Posted: 1 decade ago 2015/04/16 9:44 GMT-4
Hello Marco,
I am trying to solve a similar problem. I would like to specify both on one boundary (heat flux and temperature)
Did you find a way to get around the overwriting problem?
Thierry
Hello Marco, I am trying to solve a similar problem. I would like to specify both on one boundary (heat flux and temperature) Did you find a way to get around the overwriting problem? Thierry
