3 years ago
2023/01/10 1:07 JST
In steady state, you cannot have a pressure difference without flow.
As always, posting a model along with a description of the problem might get you some useful advice.
3 years ago
2023/01/10 7:14 JST
Hi Dave, thank you for your response. I am attaching the model I am working on below. For clarification I am using 2D axisymmetric. The pressure (0.2Pa) on one end of the shell should cause the flow (that pressure comes from an external speaker - perhaps there is a better way to define it in the model).
From experiments we know what the measured pressure should be at the other end (0.0483Pa). Ultimately we want to match the displacement of the edge at this ends with our experiment.
3 years ago
2023/01/11 2:59 JST
There is no analysis step in the model.
The pressure point constraint does not do what you think it does. It sets the reference point for all pressure evaluations; it is not a source. You must have one (and only one) pressure point constraint.
It is not clear whether your problem involves a time-dependent input pressure, a constant pressure, or a sinusoidal source at a particular frequency. Your mention of a "loudspeaker" suggests the latter. In that case you may want to to be doing an acoustics calculation.
