Magnetic force calculations
Hi All,
I hope someone will have insight into the following issue I encountered: I'm modeling a system using the magnetic fields in the AC/DC module and would like to calculate the magnetic force on metal components in a field of an electromagnet.
It seems that the result is very dependent on the mesh definition (varying from 5N to 155N depending on the mesh made) so I was wondering what is the proper way to set up the mesh and check if it is appropriate?
I would appreciate any thoughts on the issue :) thanks!
1 Reply Last Post 2023/08/02 22:53 JST
Posted: 2 years ago 2023/08/02 22:53 JST
Updated: 2 years ago 2023/08/03 0:32 JST
Hi Ivana,
magnetic force calculation is notoriously mesh dependent. Make sure you have a dense mesh where magnetic field gradients are high, like edges, corners, narrow airgaps and the like. Verify mesh convergence by parameterizing the mesh size settings.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Ivana, magnetic force calculation is notoriously mesh dependent. Make sure you have a dense mesh where magnetic field gradients are high, like edges, corners, narrow airgaps and the like. Verify mesh convergence by parameterizing the mesh size settings. Cheers Edgar
