phase dependent cuurent
hi all
how can i induce some phase dependent currents in comsol?
especially i wanna know how to make 3 currents with 120 degree different phase
5 Replies Last Post 2012/11/11 23:09 JST
Posted: 1 decade ago 2012/11/10 18:16 JST
COMSOL uses the "phasor approach so by using complex values for the amplitudes you can includ phase info to your frequency domain (harmonic) solver sweep analysis, check the doc, and I belive I have seen a model library of a 3 phse example, or was it on the model gallerie ?
It has alread ybeen discussed a few years ago, here on the Forum, the method is still the same ;)
Hi COMSOL uses the "phasor approach so by using complex values for the amplitudes you can includ phase info to your frequency domain (harmonic) solver sweep analysis, check the doc, and I belive I have seen a model library of a 3 phse example, or was it on the model gallerie ? It has alread ybeen discussed a few years ago, here on the Forum, the method is still the same ;) -- Good luck Ivar
Posted: 1 decade ago 2012/11/10 20:51 JST
thanks a lot for your answer ivar
may i ask from you to put the link you mentioned? i couldnt find it.
thanks a lot for your answer ivar may i ask from you to put the link you mentioned? i couldnt find it.
Posted: 1 decade ago 2012/11/10 21:11 JST
try a search on the Forum with PHASOR, and do the same on the help of COMSOL, and/or the PDF doc of the general user manual and the ACDC one
Hi try a search on the Forum with PHASOR, and do the same on the help of COMSOL, and/or the PDF doc of the general user manual and the ACDC one -- Good luck Ivar
Posted: 1 decade ago 2012/11/11 1:50 JST
thanks for your quick answer.
I found this link and it appears it would be useful but I use COMSOL 4.1 and this model has been written by a higher version so I cant load it. is it possible to open that? what should I do?
thanks in advanced
thanks for your quick answer. I found this link and it appears it would be useful but I use COMSOL 4.1 and this model has been written by a higher version so I cant load it. is it possible to open that? what should I do? thanks in advanced
Posted: 1 decade ago 2012/11/11 23:09 JST
link: www.comsol.com/community/forums/general/download/file/9293/Stator_3phase.mph
link: http://www.comsol.com/community/forums/general/download/file/9293/Stator_3phase.mph
