                                2012/12/09 5:32 GMT-5
                                                    Hi John
Indeed it's an important question and I find it far from trivial myself (at least not when I started to use COMSOL some years ago, and we are not alone having trouble, from what I notice on the Forum) but now I feel, as probably most fluent COMSOL users, that it's such an obvious thing that we forget to say or explain it [COMSOL doc writers: you could add some nice views and explanations about this in the users guide ;]
On important thing to understand is that COMSOL uses the integral expression approach, that is also the reason for the fuss about geometrical objects, their translformation into FEM entities (Domain, of spatial dimension n, and Boundaries of dimension n-1) onto which the physics and boundary conditions respectively are applied, and only thereafter we talk about mesh and discretization, differently from older traditional FEM programmes.
Therefore on domains the expressions are given in denisties (per volume or [1/m^3] if we start with a domain = 3D space) you should read your physics as integration_over_volume(your_expression*dV) = ... and for BC respectively one spatial dimension below.
so your BC expression Q[W] = hc[W/m^2/K]*A[m^2]*DT[K] where DT is the temperature difference
you should rather think with q[W/m^2]=Q/A)
integration_over_boundary(q*dA) = integration_over_boundary(hc*DT*dA)
And remind yourself that dV volume is basically dx*dy*dz i 3D cartesian space (or viathe Jacobian transformed into any user coordinate space) and dA is a surface element typically dx*dy for a plane surface perpendicular to Z or dy*dz for a surface perpendiuclar to X etc
In 2D-axi you need to take into account the "loop length" 2*pi*r which is in fact part of the Jacobian for the cartesian to cylindrical transformation expression
It's worth to dig into the COMSOL sub-node expressions (turn them on in the preferences)
Hope this helps on the way
                            Hi John
                                2012/12/11 16:53 GMT-5
                                                    Ivar,
That helps me immensely! Thank you! I also would appreciate some documentation on that topic!
Along those lines, though, I have another question; and I have seen this arise in more areas than in the one example I am giving you.
For the Heat Flux node, I have three different options, General Inward Heat Flux, Inward Heat Flux, and Total Heat Flux. The first two have the same unit which is [W/m^2] and the total flux has simply [W]. For my original problem, I will probably use the Inward Heat Flux, as the formula it gives (it includes a dT term) is exactly what  I am looking for.
But, what if I wasn't so lucky and had to pick the "Total Heat Flux." It's unit is [W], so does that mean I should enter in the entire heat flux of the cylinder or should I again depend on COMSOL doing an integral over the surface of the cylinder for me?
Thank you,
John
                            Ivar,
Thank you,
John
                                2012/12/12 1:55 GMT-5
The Heat Flux BC has 3 modes: turn on the "preferences Equation view" and see how COMSOL handles them.
By default COMSOL proposes heat densities in W/m^2 as a "field variable" that applies over the selected boundary.
But as for many cases in "engineering" we know the overall power, and the geometry defines the surface, COMSOL has added the "total power" choice, that is a lumped BC value (scalar or time dependent value). Within the BC node COMSOL calculates the total surface for you and applies an average power value of the Q0/Area.
The inward heat flux choice is convecting cooling/heating approach here "h" might be a field or just a scalar (or time dependent
                                2012/12/12 17:33 GMT-5
                                                    Thanks, Ivar! That helped my question! I now see exactly how Comsol is calculating the flux.
John
John
                                2012/12/13 1:29 GMT-5
still the numerics of the flux solving is still delicate (check also the KB knowledge base of the main site) Your mesh, locally to abrupt diffusion type drive changes is critical (HT or chemistry or ...) particularly in time stepping solver cases, as critical sizes for material properties, time stepping and mesh density are linked by the physics
