2012/12/19 21:33 JST
have you read carefully the help of COMSOL ? at least in v4.3a it states:
Note:
For the AC source, the frequency is a global input set by the solver so do not use the Sine source unless the model is time dependent.
so it should be set to AC for a frequency domain and SINUS for a time domain study, at least that is how I read it, but so far I have never used CIR as active source, only as passive circuitry, so I haven't checked this ;)
Note:
2012/12/19 22:26 JST
Thanks Ivar, I tried defining an AC voltage source in the circuit
and still getting errors when trying to run in frequency domain.
David
David
2012/12/20 1:28 JST
The easiest way to check this problem is to open model 12695 (transient modelling of a capacitor in a circuit)
change the study to frequency domain and try to set the voltage source so that the model will work.
2012/12/20 5:13 JST
indeed if you add a frequency domain study, set the frequency to a range such as {50 100 200 400} Hz and select CIR voltage source to AC it does not converge, you get two flat lines insted of a nice converging display plot.
But then while lloking at the solver sequence I see its in segregated iterative moe, so I added a fully coupled node, and selected the "Direct" solver node and said Enable, then solved the model , and that worked nicely, you get complex I and V terminal values, no I havent checked the results, but they do not look too bad (worth an analyitcal check) so probably the ssue was the default solver settings not adequate for this model
2012/12/20 6:15 JST
Regarding model 12695 I found that It's runs OK in frequency domain if I change the conductivity of air
from zero to one
David
from zero to one
David
2012/12/20 15:36 JST
indeed that is another issue, "0" conductivity is too little for current flow, and you get numerical underflows, anyhow "air" has a very small conductivity.
It would be interesting to compare the 1[S/m] conductivity results with the direct solving results
Indeed the results are quite different, as one should expect, from my understanding, but can you explain the differences ?
By the way it's sufficient to set the solver to "Fully coupled" (Direct is not required)
Try changing the conductivity of air 1, 1e-3 1e-6 [S/m] compared to the 1E-14[S/m] of the glass and see the differences of the current and voltage on the terminal, plot them for a frequency scan both real and imaginary (phase part)
