2013/01/05 5:21 GMT-5
If you have a tube, it's not only the diameter but also wall thicknes that should be considered, in addition to the length and the aterial parameters.
If you apply a "point" load you will get singularties, apply rather a Boundry load (surface for 3D, line for 2D but a tube is difficult to represent in 2D ;) or a Point in 1D.
Then if you want a radius of curvature you should rather apply a moment at the end and not a force, a force does not really give a regular radius of curvature.
Finally you need to define the "radius of curvature" there are some interesting threads on the FOURM try a search, somewhere one of the COMSOL employees have give a model to extract the radius of curvature for small and (?) lage deformations.
Once yo have the Radius you can define the moment (or force) as a global variable driven by the expression
(Calculated_Radius - Desire_Rradius)^2
Nagi Elabbasi
Facebook Reality Labs
2013/01/07 9:08 GMT-5
Hi David,
I suggest you apply a moment not a point force as Ivar suggested. As an initial estimate based on beam theory the radius of curvature due to an applied moment = E*I/M.
Nagi Elabbasi
Veryst Engineering
Hi David,
Nagi Elabbasi
Veryst Engineering
2013/01/07 15:34 GMT-5
I think I managed it, but I do have a question.
In my pipe, after running the analysis, and graphing the Von Mises stresses on the entire pipe, is there anyway to cut half the pipe off so I can see the stresses on the inside of the pipe?
Thanks.
Thanks.
2013/01/08 0:59 GMT-5
Check the Results - Data set - Right-click - cut plane nodes and related help/doc
