2013/01/31 14:49 JST
in the later versions (I do not believe it was in the early 4.0) you have table operations such as integration, sum, average ... on the columns
Else you must create your variable, even make a new global variable and integrate this way over the time (valid for time/transient solving)
2013/01/31 14:54 JST
Thanks! This helped.
2013/03/28 16:23 JST
I created a Global Evaluation for Power as a function of time but when I try to use the Data Series Operation - Integral, I get an error message saying "Table input type 'Time' does not match data input type 'Stationary'. Try evaluating in another table." But the data set is from a Time dependent analysis, so what would I be missing here?
Jeffrey
Jeffrey
2013/03/29 2:04 JST
Could it be the study pointer going to a wrong Data Set, or a leftover, sometimes its better to clear the table if it exist from before.
Or that you solution has not solved OK, in which case COMSOl is in default time series t=0 mode, and will go out of this state once the solver has finished in stationary (could also be a a "subversion 0" effect ;)
2013/03/30 5:36 JST
Hi Ivar,
I deleted all previous solutions and it worked.
Jeffrey
Hi Ivar,
Jeffrey
2014/06/19 19:56 JST
Hi Ivar
I have got a similar problem. I try to integrate the current density on a surface of my model but I get this message "Table input type 'Stationary' does not match data input type 'Time'. Try evaluating in another table". My solver is time dependent solver.
thank you for your help
Giuseppe
Hi Ivar
Giuseppe
