comsol script command to find a deflection of a point after simulation
Is there anyone know the comsol script command to find a deflection of a point after simulation? For example, I would like to find the z-deflection of point 37 in the model. How to write the script? Thanks.
CMS
1 Reply Last Post 2010/02/28 7:56 GMT-5
Posted: 2 decades ago 2010/02/28 7:56 GMT-5
I always forget the method/calls form one try to the other, but in those cases I do the GUI simulaton and postprocessing and look at the *_history.m or the saved .m file for suggestions
Hope this method helps, usefull in many cases to understand the COMSOl interiours (if you do not find any history files, see the COMSOL Preferrences there is a place where to select to save them, "off" by default I believe)
Hi I always forget the method/calls form one try to the other, but in those cases I do the GUI simulaton and postprocessing and look at the *_history.m or the saved .m file for suggestions Hope this method helps, usefull in many cases to understand the COMSOl interiours (if you do not find any history files, see the COMSOL Preferrences there is a place where to select to save them, "off" by default I believe) Good luck Ivar
