Postprocessing in cyclindrical coordinates
I am doing a plane strain analysis of a pipe with a crack in it.
I would like to get the stress components in the cyclindridcal coordinate system (radial, hoop stress) rather than in the cartesian coordinate system (x & y stress components).
There seems to be do obvcious way of doing this.
Is there anyone who can suggest something?
Arthur Rupel
12 Replies Last Post 2016/11/22 14:22 JST
Posted: 1 decade ago 2013/02/07 18:08 JST
This is the way to do it:
1. Add a cylindrical coordinate system with suitable axis directions under Definitions.
2. Select that system in the Linear Elastic feature.
3. Solve
4. Plot local stress tensor components ("Stress tensor, local coordinate system")
Henrik
Hi, This is the way to do it: 1. Add a cylindrical coordinate system with suitable axis directions under Definitions. 2. Select that system in the Linear Elastic feature. 3. Solve 4. Plot local stress tensor components ("Stress tensor, local coordinate system") Regards, Henrik
Posted: 1 decade ago 2013/02/22 4:49 JST
I am using plastic deformation-isotropic hardening-von mises stress, tangent modulus.--
There is no problem in defining the cyc coord in definitions. However I cannot find anyway of stating this with the material properties that I am using. This is not a linear elastic material.
Arthur Rupel
I am using plastic deformation-isotropic hardening-von mises stress, tangent modulus.-- There is no problem in defining the cyc coord in definitions. However I cannot find anyway of stating this with the material properties that I am using. This is not a linear elastic material. Thanks Arthur Rupel
Posted: 1 decade ago 2013/02/22 7:05 JST
You still have a Linear Elastic node (where you set Young's Modulus etc.) to which Plasticity is a sub-node in the model tree. In Linear Elastic there is a coordinate system setting even if the plasticity is isotropic.
Henrik
Hi, You still have a Linear Elastic node (where you set Young's Modulus etc.) to which Plasticity is a sub-node in the model tree. In Linear Elastic there is a coordinate system setting even if the plasticity is isotropic. Regards, Henrik
Posted: 1 decade ago 2013/03/06 6:57 JST
I defined the cyclindrical coordinate system in definitions.
In the linear elastic option, the only coordinate system allowed in the global. There does not seem to be a way of changing this.
When I try to plot r, theta stresses in the cyclindrical system, all I get are the x & y stresses-even in the changed local system.
There has to be a way for results to see that I want cyclindrical stresses, but I cannot find it.
Arthur Rupel
I defined the cyclindrical coordinate system in definitions. In the linear elastic option, the only coordinate system allowed in the global. There does not seem to be a way of changing this. When I try to plot r, theta stresses in the cyclindrical system, all I get are the x & y stresses-even in the changed local system. There has to be a way for results to see that I want cyclindrical stresses, but I cannot find it. Thanks, -- Arthur Rupel
Posted: 1 decade ago 2013/03/06 15:28 JST
When you define user coordinate systems, COMSOL defines the transformation matrix, and its inverse, so you can use these also directly (see the doc) COMSOL remains in the Cartesian x,y,z coordinate system, so you need to apply these transforms manually to the Results section, f you need to map back
Hi When you define user coordinate systems, COMSOL defines the transformation matrix, and its inverse, so you can use these also directly (see the doc) COMSOL remains in the Cartesian x,y,z coordinate system, so you need to apply these transforms manually to the Results section, f you need to map back -- Good luck Ivar
Posted: 1 decade ago 2013/03/06 21:21 JST
The reason is that only coordinate systems which belong to the material frame can be selected for the material definition. So if you change the setting in the coordinate system from Spatial to Material, then it will show up.
Henrik
[QUOTE] I defined the cyclindrical coordinate system in definitions. In the linear elastic option, the only coordinate system allowed in the global. There does not seem to be a way of changing this. [/QUOTE] The reason is that only coordinate systems which belong to the material frame can be selected for the material definition. So if you change the setting in the coordinate system from Spatial to Material, then it will show up. Regards, Henrik
Posted: 1 decade ago 2013/03/07 0:49 JST
Thanks! It worked.
This may be something other people should note.
Arthur Rupel
Thanks! It worked. This may be something other people should note. -- Arthur Rupel
Posted: 1 decade ago 2013/11/27 22:33 JST
3. Solve
Henrik
About the fourth step "Plot local stress tensor components ("Stress tensor, local coordinate system")", I got a question: when I choose the "Stress tensor(Spatial)", I got the same plots compare with the "Stress tensor, local coordinate system". But "Stress tensor(Spatial)" seems to be defined according to the Cartesian coordinate system. How can I get the stress tensor of Cylindrical system component?
Fan shuyu
[QUOTE] Hi, This is the way to do it: 1. Add a cylindrical coordinate system with suitable axis directions under Definitions. 2. Select that system in the Linear Elastic feature. 3. Solve 4. Plot local stress tensor components ("Stress tensor, local coordinate system") Regards, Henrik [/QUOTE] About the fourth step "Plot local stress tensor components ("Stress tensor, local coordinate system")", I got a question: when I choose the "Stress tensor(Spatial)", I got the same plots compare with the "Stress tensor, local coordinate system". But "Stress tensor(Spatial)" seems to be defined according to the Cartesian coordinate system. How can I get the stress tensor of Cylindrical system component? Thanks, Fan shuyu
Posted: 1 decade ago 2013/11/28 0:05 JST
3. Solve
Henrik
Fan shuyu
The "Stress tensor(Spatial)" is as you say oriented along the global Cartesian coordinate system, whereas the "Stress tensor, local coordinate system" has orientations determined by the coordinate system selection in the Linear Elastic node.
Note that "Step 3: Solve" is not strictly necessary if the material is isotropic, and you just want to change the display directions for "Stress tensor, local coordinate system". It is then sufficient to instead do an "Update solution" for the study.
Henrik
[QUOTE] [QUOTE] Hi, This is the way to do it: 1. Add a cylindrical coordinate system with suitable axis directions under Definitions. 2. Select that system in the Linear Elastic feature. 3. Solve 4. Plot local stress tensor components ("Stress tensor, local coordinate system") Regards, Henrik [/QUOTE] About the fourth step "Plot local stress tensor components ("Stress tensor, local coordinate system")", I got a question: when I choose the "Stress tensor(Spatial)", I got the same plots compare with the "Stress tensor, local coordinate system". But "Stress tensor(Spatial)" seems to be defined according to the Cartesian coordinate system. How can I get the stress tensor of Cylindrical system component? Thanks, Fan shuyu [/QUOTE] Hi, The "Stress tensor(Spatial)" is as you say oriented along the global Cartesian coordinate system, whereas the "Stress tensor, local coordinate system" has orientations determined by the coordinate system selection in the Linear Elastic node. Note that "Step 3: Solve" is not strictly necessary if the material is isotropic, and you just want to change the display directions for "Stress tensor, local coordinate system". It is then sufficient to instead do an "Update solution" for the study. Regards, Henrik
Posted: 1 decade ago 2013/11/28 14:33 JST
Thanks very much !
Fan shuyu
Thanks very much ! Fan shuyu
Posted: 8 years ago 2016/11/22 14:21 JST
Thanks for local coordinate selection tips . Its very useful !
Posted: 8 years ago 2016/11/22 14:22 JST
It works ! Many thanks!
