Failed to find consistent initial values on lithium ion battery simulation
I was trying to simulate a lithium ion battery problem with COMSOL 3.2a, trying to see the same effect presented in the following reference:
Premanand Ramadass, Capacity Fade Analysis of Commercial Li-ion Batteries[D], USA: University of South Carolina, 2003.
In my modified model, when the simulation starts it reports
Error:
Time 0:
Power_of_negative
Function: power
Failed_to_evaluate_expression
Expression: diff(((+(ep*sigma*phi1x)*test(phi1x)+(ap*kp*(c1maxp-theta*c1maxp)^alpha*(theta*c1maxp)^alpha*c2^alpha*(exp(alpha*F*eta/R/T)-exp(-alpha*F*eta/F/T)))*test(phi1)-0)*dvol),phi1_test)
I am a new user, don't know how to do this problem
Thanks.
Wencheng Li.
4 Replies Last Post 2011/04/19 12:02 GMT-4
Posted: 2 decades ago 2010/02/28 3:10 GMT-5
hello,
The error, Failed to find consistent initial values, has been dispeared by modifying boundary conditions.
But 'error in residual computation' arose. maybe I need to fit the value of parameters.
The error, Last time step is not converged, is still there.
hello, The error, Failed to find consistent initial values, has been dispeared by modifying boundary conditions. But 'error in residual computation' arose. maybe I need to fit the value of parameters. The error, Last time step is not converged, is still there.
Posted: 2 decades ago 2010/03/16 16:30 GMT-4
I am experimenting similar issues.
My error message is following.
Did you solve your previous issue? If so, I could be interested how you did.
I am also a new user, an advice would be more than welcome.
Don't hesitate to contact me if you need additional informations, thanks in advance.
Yannick
Error:
Time 1935360:
Error in residual computation.
Power_of_negative
Function: ^
Failed_to_evaluate_variable
Variable: dwdH, Defined_as: ((-((c^(delta-1))*(phi*(phi*(delta*beta)))))/((1+((phi*beta)*((c^delta)-1)))^2))
Variable: Dts_c_di, Defined_as: dwdH
Expression: d(((-D_c_di*cx*test(cx))-(Dts_c_di*ct*test(c)))*(dvol),{test@1})
Hello, I am experimenting similar issues. My error message is following. Did you solve your previous issue? If so, I could be interested how you did. I am also a new user, an advice would be more than welcome. Don't hesitate to contact me if you need additional informations, thanks in advance. Yannick [quote] Error: Time 1935360: Error in residual computation. Power_of_negative Function: ^ Failed_to_evaluate_variable Variable: dwdH, Defined_as: ((-((c^(delta-1))*(phi*(phi*(delta*beta)))))/((1+((phi*beta)*((c^delta)-1)))^2)) Failed_to_evaluate_variable Variable: Dts_c_di, Defined_as: dwdH Failed_to_evaluate_expression Expression: d(((-D_c_di*cx*test(cx))-(Dts_c_di*ct*test(c)))*(dvol),{test@1}) Last time step is not converged.[/quote]
Posted: 2 decades ago 2010/06/02 11:12 GMT-4
I am a new user and having the same problem. If i refine my mesh the error takes longer to appear. I am not sure what this means except it is an error in convergence since my value being raised to the exponent should never be negative. I am assuming that if you put a logical statement somewhere to prevent this it should be cured.
Alex
Hi, I am a new user and having the same problem. If i refine my mesh the error takes longer to appear. I am not sure what this means except it is an error in convergence since my value being raised to the exponent should never be negative. I am assuming that if you put a logical statement somewhere to prevent this it should be cured. Thanks Alex
Rajeswaran Radhakrishnan
Posted: 1 decade ago 2011/04/19 12:02 GMT-4
I am a new user.I am also having the same problem,If u resolved the problem before,please help me to get right...
My error code is
Time 3.746334577378822:
Power_of_negative
Function: ^
Variable: i0, Defined_as: (((k_pos*((c1max_pos-c1s_pos)^aA_pos))*(c1s_pos^aC_pos))*(c2^aA_pos))
Variable: i_loc, Defined_as: ((exp((((Far*aA_pos)*eta)/(Rg*T)))-exp(((((-aC_pos)*Far)*eta)/(Rg*T))))*i0)
Expression: d(((-K1eff*phi1x*test(phi1x)/L_pos-i_loc*Sa_pos*L_pos*test(phi1))-(0))*(dvol),{test@1})
Rajesh
Hi, I am a new user.I am also having the same problem,If u resolved the problem before,please help me to get right... My error code is Time 3.746334577378822: Error in residual computation. Power_of_negative Function: ^ Failed_to_evaluate_variable Variable: i0, Defined_as: (((k_pos*((c1max_pos-c1s_pos)^aA_pos))*(c1s_pos^aC_pos))*(c2^aA_pos)) Failed_to_evaluate_variable Variable: i_loc, Defined_as: ((exp((((Far*aA_pos)*eta)/(Rg*T)))-exp(((((-aC_pos)*Far)*eta)/(Rg*T))))*i0) Failed_to_evaluate_expression Expression: d(((-K1eff*phi1x*test(phi1x)/L_pos-i_loc*Sa_pos*L_pos*test(phi1))-(0))*(dvol),{test@1}) Last time step is not converged. Thanks, Rajesh
