saving work done in comsol 4.3a to 4.2
Please can i save a work done in a higher version of COMSOL say 4.3a to a lower version file say 4.2a, so that i will be able to open my 4.3a file in a 4.2a package. This is possible with Ms-office, why not COMSOL? Can anybody help?
1 Reply Last Post 2013/03/15 14:25 JST
Posted: 1 decade ago 2013/03/15 14:25 JST
Hello
unfortunately COMSOL developpers has not made this available, but I have many programmes CAD, math ... that does not allow to go "down" in versions. ANd one must admit that the data base and formulas used in COMSOL are somewhat different from a word doc, no ?
THe easiest is to save the geometry into a bin, most likely that you can upload again, you can save parameters and variables into text files and reload these, and then by opening both COMSOL (if you have both versions) you can cut and past the text forulas quickly from one to the other.
Personally I always remake my models in any new version, up too ;)
You could try to clear the solutions , the mesh and reset the file, and theen save it as a "m" file f you have matlab that might be read if the mdel is simple, but the risk of errors is unknown, and it's probably quicker to remake it from scratch
Hello unfortunately COMSOL developpers has not made this available, but I have many programmes CAD, math ... that does not allow to go "down" in versions. ANd one must admit that the data base and formulas used in COMSOL are somewhat different from a word doc, no ? THe easiest is to save the geometry into a bin, most likely that you can upload again, you can save parameters and variables into text files and reload these, and then by opening both COMSOL (if you have both versions) you can cut and past the text forulas quickly from one to the other. Personally I always remake my models in any new version, up too ;) You could try to clear the solutions , the mesh and reset the file, and theen save it as a "m" file f you have matlab that might be read if the mdel is simple, but the risk of errors is unknown, and it's probably quicker to remake it from scratch -- Good luck Ivar
