Part of module
Good day.
It is possible to create a report in which it was shown as part of the model?
Thank you.
3 Replies Last Post 2013/03/25 21:14 JST
Posted: 1 decade ago 2013/03/25 3:51 JST
Have you checked the Report node (last one) there are some video I believe too
Hi Have you checked the Report node (last one) there are some video I believe too -- Good luck Ivar
Posted: 1 decade ago 2013/03/25 19:46 JST
Thanks for the reply but I had something else in mind.
I have more objects in the model, and between then this coil.
I would like to create a report only for the coil.
Thank you.
Thanks for the reply but I had something else in mind. I have more objects in the model, and between then this coil. I would like to create a report only for the coil. Thank you.
Posted: 1 decade ago 2013/03/25 21:14 JST
once you have added a Report node, you get many sub nodes, you can modify these (add subtract ...) but I heve not heard of extracting only part a model into a specific (sub)report
Hi once you have added a Report node, you get many sub nodes, you can modify these (add subtract ...) but I heve not heard of extracting only part a model into a specific (sub)report -- Good luck Ivar
