Heat Transfer Coefficient between Two Solid Layer with Different Temperature
Posted 2013/03/26 13:27 GMT-4 Heat Transfer & Phase Change, Structural Mechanics Version 4.2a 1 Reply
I am trying to simulate the residual thermal stress induced by the temperature gradient between a coating and the substrate after cooling to room temperature.
The metal coating is deposited at high temperature (~1500 deg C) while the substrate is pre-heated (~600 deg C).
I modelled the geometry with a contact pair and set as an assembly. Now, apart from the convection at the surfaces exposed to the ambient temperature, there is a heat flux through the interface between the coating and the substrate.
I am trying to specify/include the heat transfer coefficient between the interface.
Could you please share your ideas on how to specify the heat flux through the interface from the Thermal Stress module and specifically heat flux from the coating to the substrate.
C
C
1 Reply Last Post 2013/03/26 16:14 GMT-4
