Parametric Study making functions
Hi there,
I am doing a parametric study with a variable T_initial for a frequency domain simulation for a fixed range of frequencies, this worked well
I need now to change the set of frequencies with a function freq_range(T_initial). In the study frequency-domain it always says failed to evaluated the function. The function was defined in the global definitions and it is plotted well in the results.
The field frequencies does not accept my function I dont know why.
6 Replies Last Post 2013/05/09 3:35 JST
Posted: 1 decade ago 2013/05/08 2:53 JST
normally the time and frequency, as well as parametrical sweep only accepts lists {...}, not continuous functions, this might be the issue you are having
Hi normally the time and frequency, as well as parametrical sweep only accepts lists {...}, not continuous functions, this might be the issue you are having -- Good luck Ivar
Posted: 1 decade ago 2013/05/08 3:02 JST
Hi Ivar that makes sense, yes that is the problem I am having since I am adding interpolations functions.
Do you known if there is any way to add a table with 4 variables?
parametric value, freq_min, freq_max, freq_step
to a parametric study?
Duarte
Hi Ivar that makes sense, yes that is the problem I am having since I am adding interpolations functions. Do you known if there is any way to add a table with 4 variables? parametric value, freq_min, freq_max, freq_step to a parametric study? Thanks, Duarte
Posted: 1 decade ago 2013/05/08 14:20 JST
I'm not sure I fully understand your demand, in the derived values I make generally at most 2 entries and then I use cut&paste to EXCEL more (which is seldom the case as I'm not an Excel fan anyhow ;)
Hi I'm not sure I fully understand your demand, in the derived values I make generally at most 2 entries and then I use cut&paste to EXCEL more (which is seldom the case as I'm not an Excel fan anyhow ;) -- Good luck Ivar
Posted: 1 decade ago 2013/05/09 0:10 JST
Hi Ivar,
I am studying the resonance frequency for a different set of temperatures. The dielectric values change with temperature by adding a function in the material properties.
I need to change the frequency range in function the of temperature during the parametric study. I tried with a function freq_min(T_initial) and freq_max(T_initial) but it did not work. Since they are continuous functions.
Any clue?
P.S. - It works well if the frequency range is always the same.
Hi Ivar, I am studying the resonance frequency for a different set of temperatures. The dielectric values change with temperature by adding a function in the material properties. I need to change the frequency range in function the of temperature during the parametric study. I tried with a function freq_min(T_initial) and freq_max(T_initial) but it did not work. Since they are continuous functions. Any clue? P.S. - It works well if the frequency range is always the same. Thanks
Posted: 1 decade ago 2013/05/09 3:28 JST
indeed that is tricky, probably simpler to either stick to the same frequency sweep, make it fine enough i.e. 10^range(-3,0.5,3) or whatever, as there is no need to stay linear: range(1,10,1000)
or then to use matlab to drive your simulation step by step
Hi indeed that is tricky, probably simpler to either stick to the same frequency sweep, make it fine enough i.e. 10^range(-3,0.5,3) or whatever, as there is no need to stay linear: range(1,10,1000) or then to use matlab to drive your simulation step by step -- Good luck Ivar
Posted: 1 decade ago 2013/05/09 3:35 JST
Hi Ivar,
It is possible to solve this problem with the matlab?
I am doing this with a constant frequency and afterwards cutout the results from the frequencies I am not interested.
Many thanks for the tips.
Hi Ivar, It is possible to solve this problem with the matlab? I am doing this with a constant frequency and afterwards cutout the results from the frequencies I am not interested. Many thanks for the tips.
