Solve es problem first, then solve emw problem using the result.
In the past I've always just used one physics. Now I want to add two physics domains and am having trouble.
Basically I want to:
(1) First: solve for the electric field between two non-flat electrodes using "es" (Electrostatics)
(2) Then: feed that final result into the second simulation, which uses electric field at each point to determine refractive index at that point -- and then solves an RF problem with that refractive index map, using "emw".
The "emw" problem is a Mode Analysis problem.
So, I do #1 above and get my electric field distribution. Then I right click on Model1 > Add Physics > Electromagnetic Waves (emw) > ...
But, at this point, I cannot select Mode Analysis! It is not there! Instead I only have the following options:
- Boundary Mode Analysis
- Eigenfrequency
- Frequency Domain
- Frequency Domain Modal
- Small signal analysis, frequency domain.
Mode Analysis usually shows up in this menu. The reason I want mode analysis is - I want to simulate the mode profile of light inside a waveguide.
Below this the two physics are listed with a "Solve For" column. If I deactivate the "es" (Electrostatics) physics in the Solve For column, then I see Mode Analysis appear above. But I do want to solve for both - just solve for one (es), then feed it into the other (emw).
An example is attached.
Any ideas?
0 Replies Last Post 2013/06/05 19:37 GMT-4
Hello David Hutchison
