Plot at time 0
I just found that the results of my simulation at t=0 are not exactly the ones that should be. I mean those results are for a time step that is really small after time=0.
You agree that time=0 is not exactly 0 in Comsol?
If you just run the simulation and then stop it before the last time step, you will see the answer for time=0
Hooman
3 Replies Last Post 2015/08/06 13:46 JST
Jeff Hiller COMSOL Employee
Posted: 1 decade ago 2013/06/07 5:05 JST
It looks like your file is improperly set up: in particular check whether your initial conditions are consistent with your boundary conditions, I suspect they are not.
JF
It looks like your file is improperly set up: in particular check whether your initial conditions are consistent with your boundary conditions, I suspect they are not. JF
Posted: 1 decade ago 2013/06/07 5:41 JST
Jean,
Thanks for the reply.
Would you pleas explain more?
I guess, they are alright. but how can I check that point you mentioned?
Hooman
Jean, Thanks for the reply. Would you pleas explain more? I guess, they are alright. but how can I check that point you mentioned? Hooman
Kondapalli Madhu Vinay
Posted: 1 decade ago 2015/08/06 13:46 JST
May be instead of recomputing you can change time locally in data of 3d plot group
