how to estimate the parameters in PDE/ODE equations
In my research, I have been dealing with mass transport processes in porous media. I used several coupled PDE/ODE equations to depict the physical process. The values of some critical parameters, such as diffusivities, are unknown to me. What I typically did was first assuming the values of those parameters, then using Comsol Multiphysics to solve the Equations and getting the profile of a variable with respect to time, then compare this model predicted profile with the experimental data. If these two can match, I accept the original assumptions, otherwise, I have to re-assume the values of those parameters, and repeat the above process till the model prediction well match the experimental results. We can imagine the above procedure is very tedious, time-consuming and low-efficient.
I was wondering whether this is a way to design an algorithm for auto-data fitting with Matlab to quickly figure out the values of those unknown parameters? Or please show me some of such examples if you know.
Thank you very much!
Jacky
1 Reply Last Post 2009/11/29 10:36 JST
Hello JUNPIN YAO
Ehsan Sheikholeslamzadeh
Posted: 2 decades ago 2009/11/29 10:36 JST
Hi there
May I know how you couple the two PDE and ODE equations together with B.Cs and I.Cs ?
Best regards
Ehsan
Hi there May I know how you couple the two PDE and ODE equations together with B.Cs and I.Cs ? Best regards Ehsan
