Time dependent study on a 3D multiturn coil inside of an electrical circuit
Posted 2013/07/31 2:40 JST 2 Replies
I am trying to model the voltage in function of time across a 3D multiturn coil inside of an electrical circuit. To do this I use the Magnetic Fields and the Electrical Circuit physics and a Time Dependent Study with a coil current calculation preceding it. In the electrical circuit there is a voltage source generating a pulse . Moreover, I have added in the Magnetic Field study a Gauge Fixing and a multiturn coil with a reference edge (the coil excitation is set to current from circuit and in the electrical circuit there is an External I vs. U). Finally, the initial value of the magnetic vector potential is 0 in x,y and z and there is magnetic insulation on the surfaces of the air box surrounding the coil.
When I try to run the simulation COMSOL 4.3b displays the following error message:
Segregated group 2
Singular matrix.
For mesh-case 0 there are 113600 void equations (empty rows in matrix) for the variable mod1.mf.psi.
at coordinates: (-0.00949828,-0.0132493,-0.010552), (-0.00882481,-0.0125927,-0.0109472), (-0.00959674,-0.0126878,-0.0111544), (-0.00884992,-0.0132232,-0.0111593), (-0.00894054,-0.0125715,-0.0118075), ...
and similarly for the degrees of freedom (empty columns in matrix).
Has anyone any idea why this error occurs?
Frédéric
Segregated group 2
Singular matrix.
Frédéric
2 Replies Last Post 2013/08/17 15:36 JST
