Help: Why is Initial value changed after calculation?
Posted 2013/08/20 21:04 GMT-4 Materials Version 4.3a 1 Reply
Hello, everyone. I build two models (both are PDEs)in one file.
For the first one, initial value is A0, a log-normal distribution.
For the second one, initial value is B0, also a log-normal distribution. It uses the result of first model as an input parameter.
Then I solve two PDEs together. When I get the solution of the second model, I plot solution at time 0. Theoretically it should be the same as B0. But I get a totally different value. Why does this happen?
I've tried to use finer mesh grid and smaller tolerance value, but it doesn't work.
Thanks for your help.
1 Reply Last Post 2013/08/21 18:16 GMT-4
