AC/DC module ground problem
i am new to comsol, i am working on an electrostatic, I want to get the electric field due to a charge distribution, but when i work without ground, i got an unexpected solution totaly, and when I use a ground, it affects the answer, so is there is any way to get electric field without putting a ground?
thanks in advance
1 Reply Last Post 2013/08/21 19:00 JST
Posted: 1 decade ago 2013/08/21 19:00 JST
what I understand from your post is that you want the electric field of a charge distribution in free space. You don't need to define ground for that but you have to make sure that the outer boundary of the model volume is defined properly and it is far enough away from the region of interest. You could consider using infinite elements.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
Hi, what I understand from your post is that you want the electric field of a charge distribution in free space. You don't need to define ground for that but you have to make sure that the outer boundary of the model volume is defined properly and it is far enough away from the region of interest. You could consider using infinite elements. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology
