Unexpected error occured whenever I click on a field for text input in tables
Posted 2013/10/19 7:22 GMT-4 Version 4.3b 3 Replies
Please see the last section of the log file as follows. As is indicated by the error message, which says un expected error occured, the detail of this error can be found at the end of the log file. However I'm unable to decypher what the log file says.
I would really appreciate any help with this.
00065:566 ERROR at com.comsol.widgets.tk.swt.swttable.f.a(Unknown Source) [com.comsol.logger]
00065:567 ERROR at com.comsol.widgets.tk.swt.swttable.SWTTable.a(Unknown Source) [com.comsol.logger]
00065:567 ERROR at com.comsol.widgets.tk.swt.swttable.e.handleEvent(Unknown Source) [com.comsol.logger]
00065:568 ERROR at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84) [com.comsol.logger]
00065:568 ERROR at org.eclipse.swt.widgets.Display.sendEvent(Display.java:3783) [com.comsol.logger]
00065:568 ERROR at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1375) [com.comsol.logger]
00065:569 ERROR at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1398) [com.comsol.logger]
00065:569 ERROR at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1383) [com.comsol.logger]
00065:569 ERROR at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1195) [com.comsol.logger]
00065:569 ERROR at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3629) [com.comsol.logger]
00065:570 ERROR at org.eclipse.swt.widgets.Display.applicationNextEventMatchingMask(Display.java:4486) [com.comsol.logger]
00065:570 ERROR at org.eclipse.swt.widgets.Display.applicationProc(Display.java:4746) [com.comsol.logger]
00065:575 ERROR at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method) [com.comsol.logger]
00065:575 ERROR at org.eclipse.swt.widgets.Widget.callSuper(Widget.java:220) [com.comsol.logger]
00065:576 ERROR at org.eclipse.swt.widgets.Widget.mouseDownSuper(Widget.java:1025) [com.comsol.logger]
00065:576 ERROR at org.eclipse.swt.widgets.Table.mouseDownSuper(Table.java:1937) [com.comsol.logger]
00065:576 ERROR at org.eclipse.swt.widgets.Widget.mouseDown(Widget.java:1021) [com.comsol.logger]
00065:576 ERROR at org.eclipse.swt.widgets.Control.mouseDown(Control.java:2263) [com.comsol.logger]
00065:577 ERROR at org.eclipse.swt.widgets.Table.mouseDown(Table.java:1909) [com.comsol.logger]
00065:577 ERROR at org.eclipse.swt.widgets.Display.windowProc(Display.java:4983) [com.comsol.logger]
00065:577 ERROR at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method) [com.comsol.logger]
00065:577 ERROR at org.eclipse.swt.widgets.Widget.callSuper(Widget.java:220) [com.comsol.logger]
00065:577 ERROR at org.eclipse.swt.widgets.Widget.windowSendEvent(Widget.java:1959) [com.comsol.logger]
00065:578 ERROR at org.eclipse.swt.widgets.Shell.windowSendEvent(Shell.java:2025) [com.comsol.logger]
00065:578 ERROR at org.eclipse.swt.widgets.Display.windowProc(Display.java:5047) [com.comsol.logger]
00065:578 ERROR at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method) [com.comsol.logger]
00065:578 ERROR at org.eclipse.swt.widgets.Display.applicationSendEvent(Display.java:4589) [com.comsol.logger]
00065:579 ERROR at org.eclipse.swt.widgets.Display.applicationProc(Display.java:4666) [com.comsol.logger]
00065:579 ERROR at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method) [com.comsol.logger]
00065:579 ERROR at org.eclipse.swt.internal.cocoa.NSApplication.sendEvent(NSApplication.java:115) [com.comsol.logger]
00065:579 ERROR at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3281) [com.comsol.logger]
00065:579 ERROR at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640) [com.comsol.logger]
00065:580 ERROR at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604) [com.comsol.logger]
00065:580 ERROR at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438) [com.comsol.logger]
00065:580 ERROR at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671) [com.comsol.logger]
00065:580 ERROR at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332) [com.comsol.logger]
00065:581 ERROR at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664) [com.comsol.logger]
00065:581 ERROR at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149) [com.comsol.logger]
00065:581 ERROR at com.comsol.gui.swt.SWTDesktop.open(Unknown Source) [com.comsol.logger]
00065:581 ERROR at com.comsol.gui.DesktopWindow.open(Unknown Source) [com.comsol.logger]
00065:581 ERROR at com.comsol.gui.CsApplication.startApplication(Unknown Source) [com.comsol.logger]
00065:582 ERROR at com.comsol.gui.CsApplication.doStart(Unknown Source) [com.comsol.logger]
00065:582 ERROR at com.comsol.guimph.MphApplication.doStart(Unknown Source) [com.comsol.logger]
00065:582 ERROR at com.comsol.util.application.ComsolApplication.doStart(Unknown Source) [com.comsol.logger]
00065:582 ERROR at com.comsol.util.application.CsBaseApplication.start(Unknown Source) [com.comsol.logger]
00065:582 ERROR at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) [com.comsol.logger]
00065:583 ERROR at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) [com.comsol.logger]
00065:583 ERROR at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79) [com.comsol.logger]
00065:583 ERROR at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369) [com.comsol.logger]
00065:583 ERROR at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179) [com.comsol.logger]
00065:584 ERROR at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) [com.comsol.logger]
00065:584 ERROR at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) [com.comsol.logger]
00065:584 ERROR at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) [com.comsol.logger]
00065:584 ERROR at java.lang.reflect.Method.invoke(Method.java:597) [com.comsol.logger]
00065:584 ERROR at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620) [com.comsol.logger]
00065:585 ERROR at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575) [com.comsol.logger]
00065:585 ERROR at org.eclipse.equinox.launcher.Main.run(Main.java:1408) [com.comsol.logger]
Wei Wang, Ph.D.
Hello Wei "Tiger" Wang
