                                2013/11/03 10:23 GMT-5
                                                    I'm confused, are t on lhs and T on rhs the same variable?
Or t is time and T = T(t) is temperature as function of time?
Cheers
Cheers
                                2013/11/04 1:40 GMT-5
                                                    hi Pollaci,
here
T is temperature, which is function of time as well as space
t-time
rgds
Anup
                            hi Pollaci,
here
t-time
rgds
Anup
                                2013/11/04 2:56 GMT-5
                                                    Your create a "dode" that is physics of type
Domain ODEs and DAEs
Then in  "Distributed ODE 1"
you enter :
da=1
ea=1
f= (A)*[exp{-E/RT}]
That shou do the jo
Jens
you enter :
da=1
ea=1
f= (A)*[exp{-E/RT}]
That shou do the jo
Jens
                                2013/11/04 6:43 GMT-5
                                                    thanks
                            thanks
                                2013/11/04 7:00 GMT-5
                                                    Dear Jens
I think "ea" should be zero, otherwise it will become 2nd order ODE.
rgds
Anup
                            Dear Jens
rgds
Anup
                                2013/11/04 8:56 GMT-5
                                                    yes, that is  a typo, Jens
                                2013/11/08 8:11 GMT-5
I got a problem here, as i have mentioned, equation contains three variable:
1. time 't'
2. Temperature 'T'
3. Variable 'X ' which is again a function of three space coordinate and time ???
* All other parameters are constant
The temperature T is obtained after solving a "Transient heat diffusion equation in solid Physics" and is used as the input to the ODE. That means the two physics "Transient heat diffusion equation in solid Physics"  AND "Distributed ODEs and DAEs(dode) Physics" should be coupled together since I need the value of T(x,y,z,t) to calculate X (x, y,z,t).
Can anyone please tell me, how to couple these two physics in COMSOL 4.2??
regards
Anup
1. time 't'
2. Temperature 'T'
regards
Anup
