Need a help in 3D geometry !!!!!!!
Hi all,
I want to make the head of the tip round with radius around 12 nm.
Can any one help me on that..... I attached the file...
Thank you,,,
1 Reply Last Post 2013/11/25 10:37 GMT-5
Posted: 1 decade ago 2013/11/25 10:37 GMT-5
you can achieve that with the boolean geometry operations. You have to add a sphere at the appropriate location close to the tip and then use the difference, intersection, union operations to generate the desired result.
Make sure you mesh this tiny feature appropriately.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi, you can achieve that with the boolean geometry operations. You have to add a sphere at the appropriate location close to the tip and then use the difference, intersection, union operations to generate the desired result. Make sure you mesh this tiny feature appropriately. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
