icons in the right click menu under linux
I just installed Comsol on ubuntu 13.04, and the icons don't show up when you right click on a node in the Model tab.
I found a command in the instalation guide, but it doesn't work...
www.comsol.com/support/knowledgebase/1086/
"If you are using the Gnome 2.X desktop and find that there are no icons in the main menus or right-click menus in COMSOL, you may need to explicitly enable the option to show icons in the Gnome configuration. This can be achieved using the following command:
gconftool-2 --type boolean --set /desktop/gnome/interface/menus_have_icons true"
Does somebody know a trick to fix this minor pb?
Thanks!
0 Replies Last Post 2014/01/13 2:57 JST
Hello Patrick Aebischer
