Boundary condition selection in simulating the surface plasmon resonance
Recently I started to simulate prism-coupling surface plasmon resonance. But I encountered a difficulty in selecting the boundary condition.
At the beginning I selected scattery boundary condition for all the outside boundary, and set one value of them into 1 as input side, and k vector to change the input angle. But the results do not match the numercial results obtained by matlab.
Later, I got reply from COMSOL support, and they changed the boundary condition into Port condition for input, and set the input power of 1W/m, and select Floquet Periodic condition for all the other boundaries except inner boundary and input-output ports.
Could anybody tell me how to distinguish the scattery boundary condition from Floquet periodic condition? When should I use scattery condition?
Thanks a lot.
The first attached file is the one I created, named spr-prism-1.mph.
The second one is from COMSOL.
According to the second one, I changed the first one into the third file, but the SPR is not correct. What is wrong then?
2 Replies Last Post 2010/09/07 16:18 JST
Hello Ling Sieben-Xu
Posted: 2 decades ago 2009/12/09 22:12 JST
Hi Ling,
could you please upload your files in .m format. I am using comsol v 3.5 and can not read your files.
thank you.
Hi Ling, could you please upload your files in .m format. I am using comsol v 3.5 and can not read your files. thank you.
Posted: 1 decade ago 2010/09/07 16:18 JST
I found the attached file (fresnel_parametric.mph) have two error
place. What do you think about that?
Firstly, the boundary condition of 5 and 6 should set to be k2x, k2y,
and not k2x, k1y.
Secondly, port 2 should set to be H0z=exp(-i*k2y*y), not exp(-i*k1y*y).
Thirdly, though I change the setup as above, the result uncharged still, why?
I found the attached file (fresnel_parametric.mph) have two error place. What do you think about that? Firstly, the boundary condition of 5 and 6 should set to be k2x, k2y, and not k2x, k1y. Secondly, port 2 should set to be H0z=exp(-i*k2y*y), not exp(-i*k1y*y). Thirdly, though I change the setup as above, the result uncharged still, why?
