moving a particle through the laminar flow
I want to simulate the problem in which a sphere moves through a fluid and study its time dependent profile
but I can't move the sphere anyway. I used the moving boundary condition for particle walls and gave it velocity, but when I animate the velocity the sphere stands and does not move.
I think it is performed by "moving mesh" or "deformed geometry" but I don't know how it is.
comsol V.4.3
can you help me?
Thanks!
3 Replies Last Post 2014/02/13 7:02 JST
Posted: 1 decade ago 2014/02/10 8:24 JST
no reply?
it's very important for me
please!
no reply? it's very important for me please!
Posted: 1 decade ago 2014/02/10 20:46 JST
Hi Hojjat,
the moving mesh allows only to move the grid, if you want to perform an interaction between a solid and a fluid you should use the Fluid-Structure Interaction physics.
It has the equations and features for fluid-structure interaction, solving for the displacements, fluid velocity, and fluid pressure.
Have a good work.
Marino Miccio
Chemical Engineer
marinomiccio.wix.com/home
Hi Hojjat, the moving mesh allows only to move the grid, if you want to perform an interaction between a solid and a fluid you should use the Fluid-Structure Interaction physics. It has the equations and features for fluid-structure interaction, solving for the displacements, fluid velocity, and fluid pressure. Have a good work. -- Marino Miccio Chemical Engineer http://marinomiccio.wix.com/home
Posted: 1 decade ago 2014/02/13 7:02 JST
Thanks!
you are right!
but if you want to make a deformed 2D geometry in which a sphere moves freely within a rectangular, what would you do?
Thanks! you are right! but if you want to make a deformed 2D geometry in which a sphere moves freely within a rectangular, what would you do?
