Bandstructure of 2D solid-fluid phononic crystal
Hi all,
I am trying to obtain the band structure for 2 dimesnional phononic crystal composed of liquid (water) cylinders in Al through the acustic-structure interaction model in COMSOL 4.3a. Although in the inverse case of Al circles in water we can obtain band structure correctly we couldn't do the same in the above mentioned case. we couldn't understand what the problem is. we couldn't find a band structure in a 3D either.
any help will be appreciated,
Thank you.
1 Reply Last Post 2014/02/12 12:04 GMT-5
Posted: 1 decade ago 2014/02/12 12:04 GMT-5
Hi Ayse,
That should be relatively straightforward since the periodic boundary condition applies only to the structural part. If you share the model perhaps I or others on the Forum can help.
Nagi Elabbasi
Veryst Engineering
Hi Ayse, That should be relatively straightforward since the periodic boundary condition applies only to the structural part. If you share the model perhaps I or others on the Forum can help. Nagi Elabbasi Veryst Engineering
